But not rear wheel drive?
I suppose you cant get torque steer on the rear wheels.
i dont use the vx220 forum when i was looking for the supercharger fitting guide it was a big secret and not available to the public at the time.I posted a how too on vx220 forum about equal length driveshaft mod and I nearly broke the Internet with various people crying about cv gaiters splitting etc. I gave up in the end as there was far too many know it alls on there.
However some people lower the vx220 without a care for steering arm and driveshaft angles so most moaned about the cv angle.
Here's the thread:
http://www.vx220.org.uk/forums/topic/134795-equal-length-drive-shaft-for-22/
Here's the thread:
i try and make as much information available to everyone on this forum as some of the guys do like vocky his input is always appreciated
i do think equal length shaft in either front or RWD cars has its benefits like equal drive to both wheelsand the gators are £13 and a doddle to fit lol
looking at the vec c m32 shafts they look the same as the vec c f23 equal length shafts will soon see when i pull the block outfor what it's worth I was originally going to use equal length shafts on my M32 conversion, but bought astra vxr shafts which were useless.
When I discovered brand new Lotus shafts for under £400 I snapped them up, the astra shafts cost me £350 used![]()
update;
you can now buy a z22se M32 lightened flywheel from TTV Racing £228 +vat
this means the slave cylinder does not now need any spacers, so simply fit the z22se M32 flywheel, Helix M32 sprung clutch plate (TTV can also supply a M32 sprung clutch plate), z22se clutch cover and the M32 gearbox with standard M32 slave cylinder.
makes the conversion a nut and bolt job
View attachment 3652View attachment 3653
