For Sale 6 Speed Gearbox
20vt
6 Speed gearbox from a Vectra c estate Z22YH.
I tried to remove the gearbox but rounded off the drive shaft bolt.
Also damaged my hand in the process and given up.
The gearbox and 50% of the engine is resting on the sub frame.
The shell is also included, still has all the suspension and braking components attached.
You will just need 4 wheels to put on the car.
The panels will be removed but the seats will remain with shell.
You could remove the gearbox and weigh in the shell.
I will probably scrap the car soon if no interest, just thought the gearbox etc may be of some use to someone.
Located in Birmingham.
£100
Some pictures
20vt
Yea, you can take as much as you want.
The passenger side drive shaft hub bolt and drivers side are different sizes on mine for some reason..the passenger side was 32 and the drivers side seems bigger.
