so here is my 6 speed conversion adventure it will take a while but i now have the box and shafts
time to get the clutch changed and the attaching parts to make it work
thanks to 20vt for the box
removing the engine and gearbox the technical way
got the box on the bench to inspect the outer bearings and the diff planetary shafts Daz knows about this
case looks good no damage to the alloy case at all and the bearing faces look good
one bearing is showing some signs of wear but not that much
all the gears look good and the magnet don't have much on it
outer case got cleaned with bilberry wheel cleaner
looks nice and clean inside now
the progress will be slow on this one but hope to have it fitted to the car before the engine get put back together
