came pre made there pressed on to the bolt and i thru the old ones in the bin so not sure if it was meant to be under or above ?Was the little washer not meant to go under the bolt head? Good work on the box, new bearings are loads biggger
it was not a spring washer thats just where i cut it and bent it offLooking at that I would say the bolts were wrongly made. The spring washer should have been on the head side of the large washer not the bush side.
seams a bit better today think i may need to bleed the clutch again and im sure there's something different with the clutch pedal like its stiff in the last partAh right, odd design then.
Hopefully it sorts itself out![]()
