nope there built to take 320nm im way past that so upgrading the main shaft bearings to larger ones for more power handling
same as you would with z22se rods
ive snapped the tangs on the syncro's on 3rd and 4th also due to the load and running a higher rpm so 3rd and 4th have been grinding so there getting done at the same time
the parts so far
gearbox pf insert astra vxr
new snr diff bearings
new case with shims and larger bearings
3rd and 4th gear kit
subframe bolts front 4 and rear 6 and captive nuts
power flex subframe bushs on the way
heated the case in front of the space heater then the bearing shells just dropped in
