Hi mate, I bought an egr cheaer earlier in the year, hopefully you guys will have the record of it. Turns out it's decided to fail on me and now the car is stuttering like a kangeroo after 10 pints of fosters lol!! Problem Is I chucked away the egr valve and I went down to my mate garage who is a motor engineer and he said its causing the ecu to mis-read something kinda like an electrical fault hence the random stuttering. When I say random I mean it was fine for 7 days, however the last 48 hours has been impossible to drive and I had to nurse the car home tonight for work not ideal at 3am
, strangley the engine doesn't splutter when the the clutch is in or when idling, only under load?
Anyway, I don't know if I can run the car without the cheater i.e just remove it as the blanking plate is in place or if you want it posted back to you to replace or if I need to pay for a new one etc, so drop me a line if possible on [email protected] so I can sort out whatever needs to be done mate.
thanks again
thanks again
