For those that wants to make a mounting backet for the inlet+ECU!
I received a drawing from a dutch forum member and made it that way so you can print it at the actual size the metal plate should be.
May be handy for some??
I saved the settings and the file can be downloaded with the following link.
http://www.yousendit.com/transfer.php?a ... C277B8EDB6
Keep i mind that there should be no print marge turned on in the print setup (otherwise the drawing will be printed to small).
At least with me the drawing was printed in 227mm x 160mm in A4 format.
For those that allready made the mounting bracket could you please check out the file to be certain that these measurements are correct??
This way we can avoid any misunderstandings or faults in the mounting bracket if there should be.
I also didn't follow any inlet mods for the astra or other type of cars that have this 2.2 engine so i'm not sure they can benefit from such a mounting bracket.
If yes, please feel free to post a link to the other topics to.
Cheers
RCduck7
