patricks
Hey guys Berto vocky evocarlos just removing my inlet manifold so i can clean the check valve between ports 2 and 3, Almost there but the below is stopping progress
1. Not sure how to remove the ecu plugs - the bits that ive circled red are in the way and i dont know how to take them off so i can free the ecu. See pic below
2. Not sure what its called but there is a hose/pipe that connects into the inlet manifold from the gearbox side and near the oil filter housing - not sure how to remove it. I can only see one pin on top of the connector that i can push down but doing so doesnt seem to free the pipe from the connector....
Help with pics is appreciated cheers..........
