Mat Jackson
Currently fitted to a vx220 - See this running here:
Coming up for sale - full VX220 ITB kit, will be coming off the car in a few weeks. Plus a few other bits and pieces:
Full kit - £950
This is the full alpha kit, which is no longer available and includes all you need to get the car up and running:
Full set of throttle bodies inc injectors
Inlet manifold for z22se head
New throttle pedal and cable linkage
Fuel regulator
Full engine loom
New crank sensor and external trigger wheel
Alpha ecu (with stage 2 map)
Spare alpha ecu (with stage 1 map)
May also have a stage 2 head and stage 2 CatCams for sale. Head is skimmed for reduced CR, has ported exhaust and updated springs to run to 7800rpm. Note - have promised first refusal to someone, but if not taken will sell.
Head and cams £650 (assuming first refusal)
Would sell all as one for £1500, giving all you need for a 200bhp - 220bhp set up.
Also available - separate Delta SCS ecu, fully open source ecu for the ITB set up as the Alpha starts to become obsolete. Complete with comms cable and connector loom to fit directly to the alpha ITB loom
Delta ECU £550
Would consider selling full lot together for a bargain price, giving you a modern, fully accessible ITB and eco set up for a a 2.2…
Make me an offer….
Full kit - £950
Fuel regulator
Full engine loom
Delta ECU £550
Make me an offer….
