The EGR Cheaters? Yes, they are still available, and you can purchase them from our online shop:Are these still available?
What's so special about the blanking plate? can I just trace round the egr and cut from plate? or is there a rubber gasket etc on the underneath?
Thanks
https://z22se.co.uk/shop/egr-cheater
With regards to the blanking plate, there is nothing special about them, they are just a genuine GM produced part.
https://z22se.co.uk/shop/blanking-plate
you need to know the voltage of the egr solenoid, usually 12v.
the z22se egr valve uses 12v for the solenoid and switches between 1v and 5v for the signal, so to create 1-3v switching would just require altering the resistance of the 4k7 resistor to something like a 6k8 or perhaps a 3k3 and 3k9 in series. Trial and error on that value.
But you also need to know which pin does what on your egr valve, as the z22se wiring is usually different than other engines.
Back in stock!
