Fitting the EGR Cheater
Should I get eml turned off due to loosing engine coolant tho. With new cheater will that cure eml coming on possibly
It depends on what exactly is bringing the EML on. Have you been able to get the fault code read?
EGR shouldn't cause coolant loss. What is the condition of the engine like? How many miles has it done? What sort of driving do you usually do (short / long trips)?
Eml came on after fitting.cheater off ebay grr
its got 109k full history
short work journeys in week long on weekend to family
coolant is weird.had pressure.check and no loss so possible water pump or heater matrix maybe im still searching through cheaper options but confused
Ta bud orderes this one
Received today ta matt.
Just quicky before soldering up and covering
looked through all pics here and semi unsure which way to solder A b d e . Obvious only 2 ways lol dont fancy soldering outside in the cold for too long
any chance of pic if possible
Just a case of knowing which way up to plug in I can trace wires then. Is it diodes up or down when you plug in lol
just dont fancy standing outside in the cold for too long lmao
chunk1982
Hey all I signed up today after a friend told me that he got a cheater for his vec from here.
I was just wondering if anyone has heard of a successful egr cheater for the z19dth engines?
I did look at the schematics but means jack to me hahaha
all the best
paul
all the best
paul
Z19DTH has to be mapped out of the ECU.
