im gonna look for my aluminium fittings, I think I want m12 banjo bolts to go into something like this on the sump and the thermostat housing. is this a good idea, 1 water and 1 oil.?
then come off the bottom of the water pump and the back of the block (if its there)
looks like you are making progress with the z22se/turbo build.
try here for genuine gm parts, gaskets ect. I got some exhaust/inlet gaskets from them, genuine gm parts at fraction of cost of Vauxhall prices
Cheers corsaZ22se dave, I will have a propper look at that.
I only need a few gaskets and then some custom water n oil.pipes n the sump n thermostat modifying then a remap.
and a intercooler pipe(had to send 1 back)
