VXJON said:sold out
andyroo said:Teckynou; Dependant on current modifications, you should see anything between 15-25bhp increase. The reason why the increase is so large is because it raises the point where peak power is made, so rather than the power dropping at 5500rpm, it continues to climb all the way to 6800rpm (or whatever your limiter is set at... who know how long the power climbs for!) which is good! Low down torque can drop slightly, unless you have a nice sports exhaust of around 2.5 inches wide, which will boost the low down torque instead. The reason this mod works is because it allows more air in at high revs where the original manifold would become a bottle neck and strangle the airflow.
Hope that makes sense! I usually reserve single syllable words and shouting for foreigners :razz:
Looking at part number, I noticed the map sensor is the same! It is already mounted on the original 2.2 manifold and can be reused...vocky said:do not waste your money on the map sensor, it does not work on the z22se anyway.
Look here:vocky said:I never realised that
vocky said:still a waste of money when you already have one
yes it is for between 2+3ufods said:Hallo from germany !!
yesterday i take my car off and i am happy to have the 100A alternator.
From www.autopartspeople.com i recieved the same mail like Alessio and poormansporsche.
But i do not know, what is this gasket is for??
--- 12589516 - c/case vent pas seal - $16.56 ---
Is this the gasket from the little hole between 2 and 3 cylinder.....can i use my old one??
Thank you for your help....Christian.
