Failed Balance Chain Tensioner
all i hear on the interwebings is ""the 2.2 is s**t the chains snap"" well in all the guys and girls from here i have done work on there cars there was only one case where the chain had snapped 40:1 not to bad odds
these engines are good if there maintained. But im defo thinking of getting something else. My cars worthless and causing issues. But cash flow is allways the problem and I do still like my car.(I dont know why)
so got all the cover off and everything looked good, rang technical support(thanks carl)
and it seams my balancing chain tensioner has failed so going on the hunt to find a genuine GM 1 to replace it.
i shouldnt be able to push it that easy.
while im there im gonna replace the rocker gasket, aux belt tensioner and aux belt.
i will update soon.
so thats defo a fail then @evocarlos?
iv txt and PMed matt but no reply yet.
i tried vauxhall but they had all gone home so i will try them again in the morning(hopefully either matt or bristol street will have 1 in stock so i can crack it off either tomorow night or saturday, thanks
yes thats a failed part its not meant to go back in once its come out theres a ratchet that stops it going in to reset them you turn it 90 degrees then push in turn back and add the pin but yours has a failed ratchet mech
I'm back from the garage, said they weren't prepared to look at it as it could turn out to be massive job! and my car is a tad obscure for them.
One thing I've noticed is I am getting more engine vibration through the car than normal especially on idle. This would be more noticable on my car with it being so light/ made of plastic.
Will video mine in the morning.
hi mate, matt has had issues with the site this morning, so lost all this mornings conversion about the noise "but good news every one"(sorry futurama) I know whats up with mine so hopefully it should be the same issue on your engine. Its not a big deal to fit, just a pain to get to(well sounds like it on a vx220) but its the balancing chain tensioner thats failed on mine. Hope you get sorted.
jimmymac
Looks like the forum restore has wiped my posts yesterday
here's my vid for reference, but it sounds exactly the same so must in theory be the exact same part that has failed.
