Failed Balance Chain Tensioner
jimmymac
Also, was yours an Fai kit also? I need to raise this with them if it is.
No GM kit from you i think
check order 1146
My order was missing a sprocket if I recall and carl and I had source another on day of fit.
I remember now. At least it's not just the Fai kits then. I'll let you know as soon as I've spoke with Vauxhall.
check order 1146
I've just had a look through the shop orders, and the order I have (4th September 2013) only shows that I supplied the Timing Chain kit, and not a balance chain kit.
jimmymac
You're right I just checked thru my old emails, I bought the GM kit timing kit from here but last minute decided to get an FAI kit for the balancer chain from eBay. So it seems an FAI are the culprits here.
Please get me the GM one, where should I send the paypal too?
Let me go get it when i get back (out for lunch with family) and I'll send you the details for payment. :)
Just to add to this, @jimmymac and @Dave Gilbert had their chains done around the same time last year. FAI kits purchased from eBay and our shop.
I'm going to be sending the failed tensioner back to FAI for them to investigate what has happened with it.
Any advise on swapping it over?.
I know I need to set the timing and how to do that.
Im then thinking about getting marie to hold tension on the chain with her finger on the guide.
I then unbolt the old tensioner and fit the new 1 and pull the pin?.
Any ideas other than that?
Got discs n pads to do on a citroen c1 after mines done. N maybe discs n pads on a punto sporting in the afternoon
I hope the weathers good.
I maintain about 15/20 friends and families cars.
So iv allways got something to do.
When im not working on friends cars, im restoring my classic mini or messing with a bike or a quad.
