About the 1514 code occuring, take a look at this:
http://www.speedsterclub.nl/bibliotheek ... ecodes.pdf
So it will occur when:
(Measured MAP) - (Throttle position estimated MAP) > 30kPascal
And the conditions for it occuring are:
* Engine is running
* RPM is higher then 600
* No throttle actuation fault codes
* Both TPS/Vref circuit fault codes are not set
* No ECU processor fault codes
So basically parameters are pretty wide and not specifically for high RPM's.
Also, from this you would conclude that the ECU has some kind of table with the throttle position value and what MAP to expect. So changing that table should make this problem go away. Silly work around would be to put the expected MAP at 100 (so atmospheric) and this fault will never occur. But don't know if that would trigger another fault
On the part of the MAP sensors, I tried both the new one that came with the 2.4 manifold and the original one I had in the 2.2 manifold. I got the faultcodes with both sensors (using the 68mm 2.4 TB)
When going back to my original 58mm TB all problems disappeared. When I placed my freshly ported 58mm TB on the car I had the same problem as with the 68mm 2.4 TB (have to say I really did some extreme porting on the TB I think
Mark
