vocky said:leaning over the clam is the killer, my body aches![]()
vocky said:so I have had to move the ecu to the expansion tank mounting bracket and have started to alter the wiring loom to suit :roll:
my mad theory........zafman said:hi vocky, what are the injectors for notsure.gif are they bigger ones cos i thought the ecu wouldnt allow more petrol in?
VXJON said:vocky said:so I have had to move the ecu to the expansion tank mounting bracket and have started to alter the wiring loom to suit :roll:
Now that sounds very painful![]()
vocky said:my mad theory........zafman said:hi vocky, what are the injectors for notsure.gif are they bigger ones cos i thought the ecu wouldnt allow more petrol in?
the ecu can adjust fuelling by 20% dunno..
what if you reach the maximum fuelling (because of various mods) :roll:
what if you fit 20% bigger injectors, will the ecu adjust the map back to standard to compensate for the bigger injectors notsure.gif
standard injectors are 252cc, 20% = 50.4 cc [302.4cc]
2.0 sc injectors are 310cc
angelplayz said:Oh and a complete "how to" would be great too as I am a complete engine novice and I may try this myself (or just give a printout of the how to to a techie at work!
vocky said:don't forget to order the gasket set![]()
alanoo said:vocky said:don't forget to order the gasket set![]()
What is the ref of the gasket set ?
daaaaavek said:This kit looks like it comes with everything needed .. gaskets, adaptor plate and manifold.
