2.4 Inlet General 2.4 Inlet Manifold Questions
markv
Wow, this is looking way better than I thought! Nice runners, smooth corners, looks MUCH better then the standard manifold :D
Defenitly going to look into this after I'm back from holiday, this HAS to make a difference :)
Mark
markv
Thanks for posting the photo's so quickly Vocky :)
Will the ECU still bolt to the new manifold? Or does that need to find a new home?
Mark
Mark
totally agree, it looks designed for performance rather than economy :D
Mark
I'm going to make a mounting bracket which will use the three mountings on the 2.4 manifold.
been busy this afternoon, made the adaptor plate for my 68mm tb :D
Ffoeg
vocky said:
your astra engine spec will love this manifold, don't you wish we could of bought this years ago :LOL:
Sure do :(, but TBH I'm surprised our American cousins have taken so long to try this, considering the availability of all the L850 family :?
the 2.4 engine only came out in 2006 and then someone had to figure out it fitted :roll:
some more pics :)
removed brackets :roll:
standard gasket and MAP sensor fitted
2.0sc tb adaptor flange fitted
2.0sc throttle body fitted, I've refitted the vacuum takeoff to the sc tb
I decided to turn the tb so the butterfly opens with the flow from the inlet pipework
xinitialz
how much hp do u think this will give on a standard engine?
seems to be a worthwhile and relatively cheap mod
I'm not sure, but the design is performance biased (about time too GM :LOL: )
the venom manifold which costs $1000 claims about 5-10 bhp and the 2.4 design looks almost identical dunno..
I think the 2.4 looks better :eek:
just whipped off the inlet manifold from my vx.
well happy :D
my ported 2.4 is a perfect port match to my ported head thumbup
my ported 2.2 inlet was a couple of mm smaller on the outlet ports compared to the head inlet ports :roll:
so this proves the 2.4 has bigger runners all the way through :D
found a major problem :cry:
the usa cars have a different alternator to the european cars and the result is our alternator is in the way by about 10mm :(
So I spent many hours trying to figure out a way to make it fit :roll:
first I tried modifying the alternator end plate, but the inlet still hit the alternator :(
then I removed the plastic end cap and bolted the +12v cable directly to the alternator and fitted a seperate suppressor/capacitor.
[the plastic end cap houses an inbuilt suppressor/capacitor and a spacer for the +12v cable]
so finally the 2.4 inlet manifold is now bolted on my vx220
So the list of things that need modifying gets longer
1, alternator - remove end cap and fit a suppressor/capacitor [done]
2, replace servo vacuum hose - longer/ larger diameter piece required [done]
3, replace servo vacuum hose one way valve - to match new hose
4, ecu mounting - make a couple of brackets
5, dip stick tube - make a bracket
6, egr - remove pipe and fit a blanking plate to head [done]
mandarinvx said:
Looks great mate 8)
thanx, it was hard work leaning into a vx220 for five hours :roll:
I have since reconnected the ecu in the original position, but it will require some brackets, nothing fancy :LOL:
I will post pics when they're made :)
