corsaZ22se
start by checking the fan works at both speeds by connecting direct to a battery.
Then I need to go thought the electrics one buy one then till I find the issue must be a relay some where
I will in the mean time put a switch in place until I can find the issue
Different question
In the bottom of the manifold there's what looks like a bolt hole to bracket in the block is this supposed to bolted together if so what size bolt do I use
Get that bolt through the manifold into the support bracket ASAP! As of know all the weight of the charger etc is on those small m6 bolts going into the head. I'll hunt out the part number I used to get my replacement from vaux
