i thought i would start thread on my go at a supercharger build i will start with the my idea of what i want i am not after huge power numbers just want it have little more under the hood so i am work to the very bottom of the scale so to start with the strip down {} {} a test fit to see what needs to be adjusted {} so i trimmed back the rad fan cover as it was hitting the TB and the air con system got ripped out it never worked anyway and extended the loom the water pipe in the left took some thinking about and went to round the side of the pulley using two pipes just need a joining section to put them together i need to make a bracket to hold the senor on the top of the manifold {} have used new hose to do all the air pipes and added to the main inlet pipe sensor and brake servo any major things i have missed so far shout up i am here to learn
Looking very nice so far mate I have a sc mapped ecu for the vectra b if you are interested? Is a CS stage 2 and comes with pulley, chip, transponder and mapped to 250bhp Also have a full dual pass charge cooler set up ready just to bolt on all hoses complete
Your sc pulley doesn't look standard. Do u know the size? Just for reference me and another lad on here are running 3.0 pulleys and we run 260. Also for the map sensor have u got the the sc one from cs as u can't use standard map sensor, If u have just take the red rubber grommet off at the end apply some tape to widen it then reapply the grommet. My map sensor is secured in with a bolt and washer I'll take a pic of mine to show u how easy it is.
I will check the pulley tomorrow I I am not sure The map sensor is the one from CS do I was told when I got the kit it has a red rubber grommet A pic would me great thanks
That looks like the standard map sensor, mine is different to that one, also that pulley looks smaller than 3" is that tape measure hooked on the pulley? Looks like a 2.9"
It was hooked on the pulley just looks off on the pic What is the difference between the 3 and 2.9 bar its 0.1 lol
Smaller the pulley more boost it will run. Standard cobalt ss one is 3.35" and runs 11-12psi Courtenay stage 2 is 3.4" iirc and runs 9psi
Well today I found a issues The TB dose not seem to fit the supercharger Is there supposed to be adapting plate or something
If your using the Z22se TB (standard) u need this bud http://www.courtenaysport.co.uk/buy...rottle-body-spacer-plate-2-2-sc/prod_832.html Did u not get the LSJ tb when u got your SC?
I have the spacer but the bolt pattern dose not line up And not I have not got the LSJ one should I have ???
When I got my kit for the US it came with the lsj tb did your sc come with a tb when u bought it or are u using your standard tb?
