astra coupe edition.
figo126
while waiting for my ecu to come back from holiday ? ive made a plate for the rear engine mount that fits to the sump on the b207 and welded to the astra g subframe , hopefully helping the other engine mounts with the extra power ,,,,,,,,,,,,
figo126
got her running Friday afternoon , got a little helper ( tofferson) , but water pump shat itself , so stuck hose pipe into header tank , we got her running really nice , just when revved over 4000 rpm it started to run 2- 3 pots ??? , turn engine off restart ticked over lovely again , guessing it needs me to down load the info off the ecu and send to peter in Holland, I'm guessing hes set it up rich for first start up, new genuine water pump coming tomorrow , so hopefully I can get it running over weekend, and what a pain it is to remove water pump still in the car , and the special tool that fits where the little cover is held on with 4 bolts ,,,,,,what a pain , need hands of a 4 year old , wont be making that mistake again new waterpump on new builds from now on,,,,,,
i have huge hands and i hate doing the water pumps on the z20nets some idiot put a turbo in the way lol
bet its going to be a right pain in the astra now you have that saab rear engine mount on to :confused:
figo126
yes pal , I removed the rear mount and the drive shaft , and yes youre right some daft twat put a turbo in the way,,,,,,,,,,,,
figo126
so water pump pooed its pants, bought water pump holding tool to make life easier mmmmm , so genuine pump came today , so had a hour fitting it ,
figo126
so engine is running but needs a learning session to fine tune the fueling but mot ran out in march , so booked in Friday for mot , I planed to use my genuine wheels for a while but ive fitted my brembo 4 pots and its not going to happen , so had to unwrap my gsi alloys that I had reconditioned and had to buy a 10mm spacers for them to fit , not much clearance but they fit,,,,,,
figo126
what can I say ( a big thanks to all in this project ) cheers for all the help in getting this done,,,, its on the road ????? , z22yh crank, b207r bottom end , z22se piston and conrods , z20net head , b207r cams , b207r injectors, td04 turbo + running dutch software , what a piece of kit the ecu is, me and tofferson had her out for a learning session Saturday evening , a bit hard to not give her too much boot ????? just need someone cheap to repair the scratches and dents,,,,,big thanks to tofferson , evocarlos , vocky ,dave gilbert , sorry if I missed anyone,,,,,,,,,,,,,,,,,,,,,
