I am building another ITB engine at the moment, but it has a z22se block and used saab b207 head.
It's getting z22yh pistons and rods, new piston rings, balancer delete, ported b207 head, port matched inlet manifold, dbilas valve springs, +1mm valves, brand new hydraulic lifters, stage 3 comp cams and a plastic cam z22yh cam cover.
A few pics;
head back from having the +1mm Valves fitted and a mild skim to clean the head up.
Ports opened up
brand new valve stem oil seals fitted
injector blanking plugs added, still need to fit the blanking plug to the saab PCV hole and drill a connecting hole so that the PCV still works as per factory.
New hydraulic lifters and exhaust cam blank fitted, a 10mm grub screw was fitted to the oil way behind the alloy plate.
