hey j thanks for your help togreat news its up and running carl ,so when do you reckon you'll take it out on the first road test
thats another reason for me to fit a proper acid batter in the engine bay it cost less and will start the car after being stood for a weekendPlaying catch up here. I'm on my 3rd gel battery. The 1st one just couldn't cope with the heat after 8 weeks and split, the 2nd lasted 4 years and now on the 3rd. I can't just leave the car for weeks on end without it being on a trickle charge. Don't think this is anything to do with the SC conversion. It was like it at PVS before the conversion going back years ago in 2007 IRRC. I reckon its more to do with the electric rear window conversion that I did. Something isn't quite right?
which one you got carlwhat a load of s**t the top hose is to fit lol
you going over the snout or round itan off cut from a vectra c![]()
This remembers me off when my alternator was failing. Yours is ok, but does the belt sit tight enough on the pulley? Does it make any squeeling noises?its a round it job the angle too tight to go over with the pipe i have
rickspeed ftw lol
next problem engine runs fine but any power draw from the interior windows,brakes,power steering,heater resets the speedo
like so
any ideas its all looks to be plugged in
That's ok you now have an excuse if you get pulled over for speeding "sorry officer my dash just stopped working"its a round it job the angle too tight to go over with the pipe i have
rickspeed ftw lol
like so
belt is on the alternator pulley i have no squeaking will check the charging voltage nowThis remembers me off when my alternator was failing. Yours is ok, but does the belt sit tight enough on the pulley? Does it make any squeeling noises?
i took it out for a spin and ive already had complaints i was only in 1-2 just bliped it in the village and some old twat said to me mom i should be arrested for driving like that lolThat's ok you now have an excuse if you get pulled over for speeding "sorry officer my dash just stopped working"![]()
It sure looks like an alternator related issue. What's the voltage? Don't think a faulty suppressor will cause this...belt is on the alternator pulley i have no squeaking will check the charging voltage now
only thing i did with the alternator was use the 100amp back plate and cut that one so if i ever needed to put mine back together i could just put the 120 cover back on maybe the suppressor is dead in the 100am cover you think that would cause this issue?
All battery cables ok? Did you use a new / refurbed 120a alternator? Might be worth changin with the old 100a one to rule things outyour right heres with the engine running
it dropped to 8v when the heater was turned on belt is fully engaged with the pulley
the answer to that is yesThis is a really impressive build Carl do you think you will be ready for trax it would be good to see all the hard work
