Project Freeze My Ass Off (rear Poly Bush's Astra G)
i realise this build thread is now 80 pages long there has been lots of work coved on my car
here are some short cut links if you were looking form something more specific to save going thru the 80 pages
working on keeping the car clean and doing a Restoration rear to front 2012-2013
recent work forum short cuts
headlight self levelling setup
Astra G headlight self leveling investigation
Retro fitted climate control system and fixings
LED speedo mod
Retro fitted headlight washer system and fixings
how to change the LED's in the radio controls on the steering wheel
handbrake cable change and adjustment
https://z22se.co.uk/resources/hand-brake-cable-change-and-adjustment.62/
Front caliper strip down and recon
https://z22se.co.uk/resources/brake-caliper-seal-replacement-and-refurb.76/
Full astra GSI recaro interior
balancer shaft delete
DIY short shifter
Retro fitted front seat airbag system
https://z22se.co.uk/threads/seat-air-bags-parts-required.23431/
Broken Manifold stud in the head removed and replaced
Supercharger Fitting Guide For Astra G
https://z22se.co.uk/threads/supercharger-fitting-guide-astra-g.24487
Repairing Dented Supercharger Inlet Laminova Cores
Fitting Charge Cooler Radiator
Reconditioning Of An Alternator
z22se alternator repair
New SAAB B207R engine build
Project Freeze My Engine Off
Walbro 255 uprated pump fitting
walbro 255 uprated fuel pump fitting Astra g
Diy Crank Pulley Tool
Drive Shaft CV Boot Replacement
Astra VXR front brake conversion
Balancer shaft delete
walbro 255 uprated fuel pump fitting astra g
Vectra B rear pads/shoes/disc change
https://z22se.co.uk/resources/vectra-b-rear-pads-shoes-disc-change.89/
ok so its 5pm and im set to take my rear beam to work in the morning for 8am to get it shot blasted
looks like its going to be a long cold painful night of me shouting swear words at the bottom side of my car lol
pics to follow later
here's one to wet yer whistle
Daz
Shudnt be that bad a job to get off.. but with frozen fingers its gonna be painful.
right im done did not start till 7pm had a mahoosive tea to eat lol
90% of removing it was easy as most of the bolts had been copper slipped in the past the 10% that went wrong were with the white line anti roll bar the bolts had seized and sockets would not fit had to take the bolt out from the chassis to get room to fit the spanner in with the ARB off the rest was easy
here are some pics not many was really in to the job :)
before (wheels off)
one hub off
two hubs off
tadarrrr
the lonely after pic
in the pics you can see a icicle hanging from the back bumper
but it really was not that cold had some work gloves on that helped with keeping me hands warm
and i only had to put £2 in the swear box when the bolt snapped of the cheap aussie ARB
i've got 4 bottles of schutz in the boot ready for tomorrow :)
thanks Matt
just got in from my trip to work
here's what the ARB and rear beam look like now
in shot blast
after 4 rotations
back home clean as a whistle
just need to cut the old bushes out and then respray and start putting it back together
bush's out used a blow lamp and a huge t*** f*** stick
had an error with the 1st coat of paint it appears hammerite don't like being mixed 50/50 with thinners is like water
got it sorted now just added more paint its prolly more like 70/30 now
waiting for it to dry then spray the other side
stupid thiners mistake cost me some time and made a mess of the bottom so had to make it right
here we go again
more later :)
That does look too good to go back under the car. Are you doing the RARB the same, or leaving it off now?
ive got some silver paint for the ARB but need to repair the mountings before it can go back on ive got all new bolts for it just a case for getting all the old ones off it
the heater made all the difference to painting the rear beam
Looks spot on.
ok so i went on to refit the arm here's some pics
copper slip every where
new bushes
i needed a way to get the beam under the car with out damaging the paint work hows this :)
only a case of bolting it up to the chassy then
got round to fitting the hubs and brake pipes springs and shocks
but when i was trying to bleed the caliper there was way to much air rechecked the nipple as it was blocked and stiff to get out
looks like it had wrecked the thread on removal
i tapped it out to 1/8NPT and fitted a refrigeration fitting with a shrader valve (tyre valve) its sealed and bled
