Walbro 255 Uprated Fuel Pump Fitting Astra G
Engine / Transmission Walbro 255 Uprated Fuel Pump Fitting Astra G
Walbro 255 Uprated Fuel Pump Fitting Astra G - Walbro 255 fuel pump
after fitting a supercharger to my z22se the were needs to fit an uprated fuel pump
here is how to fit a walbro 255 pump into the standard tank holder of an astra G
first off you will need to remove the lower half of the rear seat bench
this can be done by lifting it up vertical and tapping the locking wires out the holers
once the rear bench is removed you will see a round cut out in the carpet heres where the pump lies
under the carpet there is a weather seal /...
Back
