The box will defo mount up but as carl says, the clutch, flywheel and ecu/wiring will need to be swapped or modified. But the loom may just be plug n play n then just programme the ecu
Not sure. More the ecu that controls the auto box sensors etc. Do the z20net 2.0turbo cars come with a auto box? I k ow the saab aero does which is a net
Would probably be better getting bits off a saab then. I might be able to help you out with parts, a bloke i know brakes vauxhalls in doncaster n im sure he had a aero auto.
