Muncher83 said:The existing stuff is 10.5mm internal diameter servo hose, I just bought a new section of 10mm internal diameter hose from a motor factors for a couple of quid.
andyroo said:Muncher83 said:The existing stuff is 10.5mm internal diameter servo hose, I just bought a new section of 10mm internal diameter hose from a motor factors for a couple of quid.
I'm confused now... the 12.5mm stuff fits the servo valve perfectly (the valve which Vauxhall quoted as being 12.5mm) so is there all the same stuff again in 10.5mm? When I asked at the parts desk I was told the valves only came in 8.5mm and 12.5mm :?
And how did Vocky and others fit the servo pipe over the 2.4 manifold outlet!
I thought I had this figured out... I wish the manifold would get here so I could finalise my plans!
Muncher83 said:All of my existing servo hose (recently replaced by Vauxhall as part of the recall) is labelled as 10.5mm ID.
vocky said:I knew I should have used a bigger hose![]()
still boiling water seems to do the trick, BUT be careful the takeoff is quite fragile :roll:
I bought some new 10mm ID servo hose, it was a bugger to fit :roll:Lightning Coupé said:Did you use the standard Vaux 10.5mm hose vocky onto the intake nipple? There is no way on earth that the 10.5mm stuff I have would fit even after boiling the bugger, If i'd pushed any harder Id break the thing? I'd recomend using a brake servo plug and a little rubber hose to everyone.
blue se2 said:I'm sure my servo pipe is 13.5 from mainfold to one way valve then from valve to servo it's 8.5?
vocky said:is that 13.5 mm outside diameter or inside diameter notsure.gif
andyroo said:Oh, is that large to the manifold, small to the servo then?
andyroo said:I meant specifically on Blue Se2's car
so that's one less part to buy for yours, I'm not sure if the servo hose will be long enough to reach the new position on the 2.4 inlet manifold, you could cut it in half and use a piece of the hard plastic pipe like on Blue Se2's picandyroo said:My VX has a large connection on the manifold and the servo, like your vectra
andyroo said:That should be 12.5mm to 8.5mm... if you get the servo valve with the vacuum take off on it that goes from 12.5mm to 12.5mm (part no on previous pages) you should be alright. Lightening coupe managed to fit a 12.5mm hose over the 2.4 manifold end so it should work alright. When i get my manifold i will be able to confirm!
