jnaisby
Well my cars has been rebuild, bottom end checked with new piston rings changed and full recon + port and polish head, its not even done 1000miles yet!
but the problem is when tried starting the car a loud bang came from the engine bay from the inlet manifold, after the engine was just turning over at normal speed but no start just starter motor pulling it round. this come out the blue when from a hour or so before it started no problem :/. when I removed the rocker cover I seen one of the cam followers off and looked undamaged on inlet valves cyl 3, after checking the rest were fine apart from cyl 1 cam followers and the other one on cyl 3 just push off and I could take them out which I didn't think should happen :/. chain is soild and don't look like its jumped.
I've left it for the time been and don't know what to do next I don't wanna just put it back together without knewing what happened in the first place, and of course save any more damage. any tests I can do with the way its acting now?
any help would be great thanks jnaisby
