Stage 3 or 4 SC engine - built from a saab b207 - £3000 (fitting can be arranged)
Built less than 1000 miles ago
GM Racing +0.5 oversized valves
Fully ported and polished saab cylinder head
CompCams Blower camshafts
Supertech double valve springs
Wiseco overbore forged low comp pistons 8.9:1, rebored block to suit.
Eagle steel rods
Balancer shaft delete
Balancer chain delete with Craig Davies electric water pump - but if wanted it will be fitted with a gm water pump and balancer chain FOC
Z22yh crank - this can be swapped for a polished z22se crank FOC
Saab high capacity sump
can also supply with lsj ecu with all components and hp tuners (extra)
also have a load of powder coated parts to go with it
with the engine if the buyer wants i can have vocky swap the cranks for a polished 2.2 crank, also if you didnt want to run a electric water pump can have this fitted with a balancer chain
£3000 fitted
Eagle steel rods
£3000 fitted
