thanks daveThat handbrake cable will be less prone to rusting . I've seen a similar Astra/Vectra rear brake setup before. Nice, good work Carlos
the issue i had with mine before was the cable rubbing thru on the trailing arm then water getting in as you say that will never happen here unless the wheel takes a bite lol
thanks matt i do think they will be a good addition to the systemNice work there Carl, will be interesting to see what you think of them once they are bedded in.
lol what am i 12Don't be a chav and don't be testing it out in the local supermarket car park with hand brake turns
stopped at the local paint supplyers and got a shot blasting gun ive bought a 2nd drivers caliper for the pin that broke
new pins to fit the calipers the right ones this time lol
after runing the car the pads look like there in the right place so the modifcation to the caliper braket are right
