Following my engine failure/swap I have the following that I don't really want to hang on to!
Either would be useful for someone who is planning an upgrade for more power as they will let you build a spare engine out of the car in your own time and only swap when you are ready
With the right bits replaced and work done I imagine both engines will be better than new (i.e. new pistons, rods etc)
Engine one
- Complete standard head with cams, lifters, the whole lot. Two valves on this head had kissed the head, minimal marks on the valves only. This head came from a separate engine to the bottom end below.
- Full standard bottom end (50k). Big end bearings failed but crank looks ok. Main bearings also ok. Pistons/rods/bores all appear fine.
Engine two
- Complete, unopened z22se engine from a 2003 vectra estate.
- Has done 182k but I have heard it running and once warmed up it sounded fine with no alarming signs.
I guess people may want to split them (i.e. if you just want a head or a block) but I thought I would offer them as complete units for simplicity first. Both engines should be relatively easy to refresh the "consumable" parts.
PM me if you are interested in bits.
Engine one
Engine two
