Astra G Subframe bolt sizes
wils978
Does anyone know what the bolts sizes and codes are for the rear subframe for an Astra G 2003 2.2 coupe/Cab? It's the bolt that's on the O/S rear where the triangle bracket is. I'm after the single one that links both the triangle and subframe to the main chassis.
There are 3 bolts to the triangle, 2 on one side and 1 on the other. it's the single one by itself. I can take a picture if no one understands which bit.
I was doing MOT checks and noticed the bolt missing :-O
Thanks!
wils978
Nice one! is that the vauxhall part number? so I can go into the dealers and get the bolt. The numptys behind the counter never understand so if I go in with a part number then hopefully they won't get it wrong.
