I also spoke to cobra, but as they don't make a 3" system for the corsa it was a bit pricey and their cats have bad feed back about life span.
saw infinity at coombe, looks very good plus they are much closer to me. guess you would be between cobra and them?
i wont be using one of there cat i have the £75 200cell one thats just fine
they have neglected to get back to me again today but they had good reason no internet for 3days lol
I be interested in your current exhaust when u swap it over. Its 2.5 inch?
do you mean all of it of the front pipe ? the cat back is 2 1/4" the down pipe is 2 1/2" sleeve to fit 2 1/4" but the down pipe will be cut up so i can reuse the cat
so i finally got round to giving the pump controller control of the fan
here it is again ""the plan"" it's wrong btw lol see further down
10 years of chafing
still connected but manky
5 pin relay fitted at 1st it was fitted with the the trigger to the coil to earth
then found out it did not work i was also expecting the a/c fan to be on
after RTFM! i saw its a negative switched so a small change got it working and was happy to see the main fan running
here's the updated schematic
i also swapped back to the 1st pipe layout and ive now got heaters lol been going to work all week 7 mile and the gauge never passed 75c at any point lol
as for the fan it's working fine and the main fan comes on full bore for about 15 secs and does the cooling cycle
ive now got the ability to set the fan to come on 3* after 75c 80c 85c 90c 95c and keep the water temp at the set point
and its also good to report that there is no lamp on the dash the coolent module did not care the fan was running when it was not telling it to
