fitted the wideband sensor and run the wiring into the carSo what progress we made today on putting the car all back together??
Have u installed your new running set up that we discussed about the other (Extra injector)?
fixed the pulled bolt on the heat shield new rubbers on the zorst
went to test the wideband and thought hmmm rich
yep its mega rich and i can't find the issue
the said FIC has not been received yet
+1mm valvesWhat have you added to the engine build that's different from before other than cams? Is that still on cold start or is it up to temp? If reved does it always return into the 10's
done a log with opcom on the ecu but im still none the wiserIn theory them mods should make it run lean due to the extra airflow.
Have you wired the gauge into the ecu?
Ecu must be going into a safe mode and chucking more fuel in.
Getting frustrated with it?scrap it!
dewismotorsport ive not wired in the narrow band output from the controler its still running on the factory sensors
i did go out and cut the plug off the t/b made it longer and fitted a different plug the wideband now reads 14.0
but i think the coolent temp sensor is shafted as it not putting the fans on till 98c
or the fact its in the return from the heater matrix now
need to find a way to run the main fan without relying on the coolent module and its errors
im thinking relaly form +12v to the actual fan + then triggered from the water pump controller was going to do it today but got p**sed off with trying to many diffrent things
i guess a map would cure itAh now 14's are more like it for idle (14.7 is stoich) and mine flutters from low 14's into 15's as the lambda is doing its fuel trimming at idle.
The problem may well just be the cams and enlarged valves are making the ecu work outside of its set values table so it's defaulting and chucking more fuel in to keep it safe.
Ultimately it needs a remap though
well i was a thought getting rid of the moduleGlad it's running better, I wouldn't worry too much about idle add for now, as long as it runs as mapping with quickly sort the idle map out, if it's like aftermarket maps, they run a separate idle and cold start map, the idle map doesn't get taken over from the main map until after 1500rpm (well that's how my Omex 600 works). You not thought about ditching the module and just using a electronic fan switch like I've just bought?
thats good advice i,ll remeber that next time somone books the monday at cs and ive got to fit a sc i
got a new coolent sensor today but not fitted it yet im hoping onces its fitted i get more like 14.5 with the fluctuation of the fuel correction if i hold it at 2000 rpm its bang on 14.7 lol
the new plug on the t/b has made the difference one of the pins in the plug was tarnished has been for awhile taken me till now to do it
but its now got to learn the t/b values due to the battery being off again
thinking of tapping into the feed from the ecu for the coolent module to put the fan on
