Hello to all here, first, excuse me for my bad English, i'm French LOL!
I got an Vectra B Caravan Sport Zender, with the Z22SE motor, 146000kms and i got a ig big problem:
When i accelerate full gaz, for exemple in the second gear, at 5000rpm the motor cut, an re goes, and re cut!!!!
If i no accelerate full gaz, i can go to 6500 rpm, but in full gaz, impossible!!!
The car smoke grey with bad odor (not egg)...
But she start perfect, and have there 4 cylinders....
When she not drive, in stop condition, if i done gaz gaz gaz, when the rpm shut to the idle, she do like a rallye car....
I change the 4 spark plugs last week, the oïl and filters, the air filters, and tomorrow the fuel filter
The ignition coil looks ok, but the spark plug are a little black...
I remove and cleaned this (i don't know how it say in English)
Always the problem...
This morning, i does a record with the OP Com, i compare the results with my Astra G Z16XE and i see for the Z22SE "tank sensor 0V" and 2 Liter!
The Astra record:
The Vectra record:
The dash board say me i got 11 liters in the Vectra, but 2 liter and zero V on the record engine!
For the Astra, 15 liter, for 16 liter in the record engine, so it's correct
I shunt the 2 wire of the tank (Brown/white with black/blue) and no difference, only the Dashboard goes to 0 liter when i does it....
The EGR valve is OK, not black....
What can be the problem??????
The lambda?
The regulator pressure of fuel???
I don't understand...
No check light on Dashboard, and no error code on OP COM...
Help me please!!
Big thanks from France!
Drago
The Astra record:
The Vectra record:
The lambda?
Help me please!!
Drago
