right so im posting this info here so its all in one place and i can use it as a reference to see how to get it working
heres the plug and pin outs to the ic plug
overall view of the LSJ wiring
each lsj coil has 2 wire that are common across the loom A + D
the coils in the z22net rocker cover
adoption of the lsj coil loom
the z22se throttle body plug is a direct fit for the coil loom
- A: ignition 1 voltage (+12v)
- B: IC timing control
- E: Ground 0V
- F: not used (cam signal)
- G: IC timing control B
