Me and a friend just spent saturday trying to fit my ported head and new cams, but we got the old head off, took the cams off the new head in preparation for the new cams, and noticed that two of the valves weren't shutting properly. It seems the 'perfect'/'as new' head I got off ebay actually has 2 slightly bent valves, and after a quick check with paraffin several more that aren't a good seal
So... Does anyone know of a good, relatively cheap place that I can get some OEM valves from this week? Are there any uprated ones that don't cost much more? I'm also wondering whether I should invest in some stronger valve springs now (I'll have Stage 2 comp cams) - can anyone recommend any sensibly-priced ones?
Also I might have some lifters that are iffy - I don't fancy spending another £160 on a new set, so can anyone see a problem with swapping in some from the old cylinder head? While I had everything off I realised that while I have a new head bolt set, I don't have new bolts for the camshafts - is it going to be a problem to reuse the old ones?
Looking at the most bent valve, it is about 8 thou out... So it's not huge... could that have damaged the valve guide?
thanks,
thanks,
