patricks
vocky evocarlos Changed my balance chain and balance chain tensioner on my 03 astra. Refitted everything and rotated crank twice – all normal. When I started engine I heard horrible noises coming from top end sounded like tapping and there was also some screeching coming from timing case. Timing pics below of both chains.
I stopped engine added a bit of oil and restarted the engine and the noise from top end stopped after 20 seconds but was still noisy/screeching on timing case and then went quiet and sounded completely normal after the engine threw off the auxillary belt. I reversed the car and drove back into garage it felt normal but the power steering no longer works. Too scared to start her again now….
What have I done wrong???? My real concern is
1 the oil pump is fooked I rotated it a bit so I could get the engine pulley back on could that effect its working and hence top end noise when i first started it?
2. i have done the timing wrong on either or both chains
Obviously I must be fitting the aux belt tensioner incorrectly too – I don’t know what im doing wrong – my procedure is I put the belt on engine pulley then around alternator and air con compressor then put the belt tensioner on and pushed down on the belt whilst I turn the bolt.
I reaslise that’s a lot to ingest………
