NICKYB
right the time has come for this to go
i love it but i carn't bare to see it sat on the side of the road so i'd rather it go and get something else!
its a 2001 '51' plate vectra estate
T&T feb 2010
64,000 miles and new chain kit done 2K ago by appy
most service history, has had services every couple of thousand miles since i've had it!
runs great and never have any major problems
engine:
polished rocker and pipework
badged engine cover
polished brake res cover & relay cover
red/black vauxhall battery cover
K&N panel filter
de-restricted airbox with 3" direct air-intake
red caps, brake res, washer, rad water, oil filler and dip stick
ported & polished TB
70mm silicone air intake pipe-work with breather
rad cover
blanked off EGR and removed re-circ egr pipes
pre-cat removed
not 100% sure which exhaust system the car will have yet be can sort this out with buyer.
run a 157 bhp rolling road in august but that was before many of these mods, should be over at least 160bhp now so its a good strong engine.
exterior:
full SRI spec (irmy spoiler, etc.)
front GSI pre-face copy bumper with red air-intake & tow eye
laguna front splitter
upper & lower black mesh grills
blacked out carello headlights
ice blue xexon bulbs (red led sidelights but have blue or standard) & chrome indicators
flat blade wipers
smoked side repeaters
re-furbed black/red door badges
full window tints (limo black going to medium on front windows)
short ariel
de-badge boot with irmscher badge
removed rear window seal (looks cleaner)
fiat smooth rear wiper
interior:
standard SRI spec half leather seats with side airbags with minor wear to bolsters
titanium centre console, speedo surrounds etc.
standard CD headunit
wheels & tyres:
17" astra coupe se2 wheels re-furbed in powdercoat gloss black (1 mark approx 15mm long on spoke) with red rim which can be removed
215/40/17 yoko parardas (5-7mm) tread
suspension & brakes:
fully height adjustable jamex coil-overs (6 months old)
standard brake set-up fronts only done 5K
bad bits:
the paint work is very good with a couple of imperfections i.e stonechips to bonnet and bumper, theres bubbling under the rear passager arch and a pin ***** on wing, if your genuine interested i'll take close ups of the areas and send them to you!, the running of the car is great, and the other thing is that with the height its at and the splitter i catch it coming out my drive and speed bumps so if you have bumps etc. near you it'll either need lifting or removing splitter!
the plate will be changed back to a '51' plate
think that is it, i'll add if i remember anything else and feel free to ask any questions!
i am looking for around £2500 o.n.o
the price can be altered as wheels can be changed to standard 16", engine parts i.e TB, silicone air intake can be changed to standard, splitter removed, or you can even sort you own exhaust out (i need to find one to go with it yet) etc.
i would also be interested in a part/ex with another vauxhall (astra, vectra, zafira) W.H.Y
not sure why its chopping some pics off on this forum but you get the idea!
T&T feb 2010
engine:
badged engine cover
K&N panel filter
rad cover
pre-cat removed
exterior:
flat blade wipers
short ariel
interior:
wheels & tyres:
bad bits:
