I have metal adjustable drop links on mine and the kit I got came in 3 different lengths for about £45 so you can try 3 sizes till you have the right size but mines pretty low and I'm still using the standard length so I kind of Wasted my money in a way as I could of used standard ones for about £8 each.
I've been told that standard ones are fine up to 60mm lower than that you need shorter ones but maybe someone else can confirm that?
dont think i will ever go to coilovers
genuine gm shocks 9 years and counting there still good only recently fitted new arb links standard size but then any lower than 30mm round here is pointless plus i have to go over 8 speed bumps to get to work each day and i like the smoother ride now im getting older hehe
After seeing carls car I seriously thinking about going to standard shocks I don't like how solid my suspension it the roads just aren't good enough anymore
Okay, got my answer from KW: Good Morning, Thank you for your enquiry. You are able to use the standard drop links. If you have any further question please do not hesitate to contact us again.
Oh yeah without a doubt the standard shocks are good I won't be replacing coilovers after being in yours powerflex bushes standard shocks and lowered springs is a really good setup
Wheel dimensions? Im using Irmscher R18 8J ET35 with 215/35R18 tyres and back was rubbing everything with coilovers, until i folded arch groove(idk how to say it in english).
