Ok... one more time on coolant lines.
I'm getting a bit mixed up cause a VX may have a bit different lay-out as other vauxhall's... Not allways sure how to see the pics etc.
So here's the schedule from MarkV on the VX coolant flow:
For the idea: Rad is in the nose. Temp sensor is on the exhaust side of the engine (so at the back of a VX)
A) If I am correct, the z20net has a return in the "main outlet"? Correct?
B) The US Cobalt guys say to put the return into the "secondary outlet", straight back to the reservoir. I think this would not be such a great idea since you are warming up the cold water that is suppose to cool the engine (warm out and warm in....). Correct?
C) Tapping into the thermostat means you recirculate the hot water into a cold circuit and putting hot water into the engine. Not that good. Correct?
I would go with option A. Any comments on this one?
