Starting problem
jordy
Hi all strange sudden problem.
My 2.2 direct zafira had a problem with the fan selector which I have fixed once before. White plastic wheel up behind the dash just above the pedals one of the arms jumps out of a little groove. Fixed that ok but suddenly won't start just keeps making a clicking noise from the engine.
Some other strange symptoms tho when try to start - rear parking sensor beeping sometimes and a beeping noise from dash could possibly be front sensor but not sure. Also display on dash computer saying range 0 suddenly even tho gauge says half tank and Def has petrol. Codes are 1614, and 1616 and these come back after clearing. Seem to be immobiliser or sim related.
Is it possible I've unplugged something by accident while had my hands behind dash fixing fan tho? It was very cramped for space.
Thanks as always
jordy
Was still the same this morning so I thought I would try jump starting it again even tho id already tried that and it didn't make any difference. But this time it did the trick started fine with jump leads on and been fine ever since. Most peculiar. At least it's working tho.. For now
