Running rough
Help!!!! This car is really getting on my t**s! It's always had a bit of a lumpy idle ever since I got it in 2012 and was always very lumpy coming off of fast idle but now it's hunting like mad on idle. Ever since I've had the car it's had the engine management light on and diagnostics showed position 2 lambda. Recently I've had the timing chain replaced and today I've replaced both lambda sensors, throttle body and coolant temp sensor, still running rough even after ecu reset. Checked compression, all good.
What next can I try before I drive the car into something solid?
MikeS
need some diagnostic readings from sensors
I know these engines run rough when in limp mode, so clear the fault down and see if that changes
