i like shiny new toolsspecial
got plenty of room now i cleared it out you will have to pop down and have a lookYou will need a second bat cave soon!
yeah there nice but a bit steep at £118I do like the mitutoyo verniers used to use their stuff when I work in fabrication, we found it much more accurate than cheeper brands and better life span.
right went out and did a bit of playing with the crank
cleaned all the holes out with break&carb cleaner with my new brush
journals are all clean and tidy now the shaft is still a bit dirty hopefully it will get cleaned if i use it
new tool made life easier
each journal got measured 4 times
w1 = woodruff key end w2 = same journal but other edge
f1 = flywheel peg so 90% difference to w1 and f2 is as above
some mixed readings but engineer dad says after .00 theres not much difference
used z22se crank has 55.980mm on most
brand new saab crank 55.993
