problems with my car
solorider
i have a egr cheater and i have had problems since before and after fitting,the eml will come on and stay on,now i have a working opcom i can get some readings
OP-COM 100219a - PC based diagnostic tool
hkj
OP-COM - KW2000 Communication Window> 2001 (1)|Astra-G|Engine|Z 22 SE
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0TGF671B004529
vehicleManufacturerECUHardwareNumber 09391283 BC
systemSupplierECUHardwareNumber: DEL 011A16265590
systemSupplierECUSoftwareVersionNumber: 0007
systemNameOrEngineType: Z22SE
RepairShopCodeOrTesterSerialNumber:
ProgrammingDate: 20010424
Identifier: 1A81
Total number of fault codes: 1
P1404 - Exhaust Gas Recirculation Circuit Range/Performance (Closed Valve)
(00) - Present
im also getting a rich mixture showing on opcom tests
hkj
OP-COM - KW82 Communication Window> 2001 (1)|Astra-G|Body|Engine Cooling Module
KW82 protocol initialized.
ECU ID= CU,24409214,3900,4999,1701,,
Total number of fault codes: 4
00163 - Engine Coolant Temperature, No Signal
Not present
00002 - Engine Coolant Temperature, Frequency Out Of Range
Not present
00044 - Malfunction Indication Lamp (MIL), Low Input
Not present
00164 - Engine Coolant Temperature Incorrect Signal
Not present
I would check the coolant temp sensor and wiring dunno..
the egr cheater can sometimes give a code because they are too fast at switching from open to closed, but it doesn't normally show up unless another code is present (y)
solorider
i cleared the codes and when driving localy no eml came on,as soon as i start to cruise at 70mph the eml comes on and stays on,the only code that comes up is p1404 and p0404,all the others codes noted preciously have not come back
MikeS
worth doing the actuator test on the egr valve using opcom
the cheater should respond
