Morning guys
Basically the just of it is i seem to be losing oil and blowing a white ish smoke at high RPM, i have been told this is either rings or stem seals but
- well today finally received the egr cheater and fitted the plate etc, also received the opcom so happy days. this evening after removing the fault codes i done a proper run
- So 3 runs in low gears high rpm in 1,2,3
1st Run
1st gear to 6k grey/whitish smoke from rear only after 5k
2nd gear upto 5.5k very little smoke only after 5k
3rd gear upto 5k no smoke
2nd run
1st gear upto 6k no smoke
2nd gear upto 5.5k little smoke only after 5k
3rd gear upto 5(ish) no smoke
3rd run
1st gear upto 6k grey/white smoke only after 5k
2nd gear upto 6k no smoke
3rd gear upto 5)ish) no smoke
i assumed if it was seals/rings it would either constantly smoke or smoke all the time at high RPM. Also the smoke isnt as bad as it was with the broken centre section lol
I have also read the codes and they are
P1574 - (0)
P0405 - (0)
P0571 - (0)
I also took a CSV of all the settings at idle see below See if anyone notices anything out of the ordinary (this was taken at idle)
OP-COM 100219a - PC based diagnostic tool
Date and time> 13/09/2013. 18:4239
Selected model> 2001 Vectra-B Engine Z 22 SE
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: **************
vehicleManufacturerECUHardwareNumber 09391263 BA
systemSupplierECUHardwareNumber: DEL 011A16265590
systemSupplierECUSoftwareVersionNumber: 0006
systemNameOrEngineType: Z22SE
RepairShopCodeOrTesterSerialNumber: Not programmed
ProgrammingDate: FFFFFFFF
Identifier: 1A05
Measuring blocks information:
Battery Voltage 14.1 V
Main Relay Active
Fuel Pump Relay Active
APP Sensor 1 (Accelerator Pedal Position) 1.02 V
APP Sensor 2 (Accelerator Pedal Position) 4.51 V
Calculated Pedal Position 0 %
APP at Idle Position (Accelerator Pedal Position) Active
TP Sensor 1 (Throttle Position) 4.14 V
TP Sensor 2 (Throttle Position) 0.88 V
Calculated Throttle Position 7 %
Throttle Position Idle
Engine Speed 814 RPM
MAP Sensor (Manifold Absolute Pressure) 0.97 V
MAP Sensor (Manifold Absolute Pressure) 29 kPa
Coolant Temperature 2.32 V
Coolant Temperature 82 °C
Intake Air Temperature 1.92 V
Intake Air Temperature 28 °C
A/C Information Switch (Air Conditioning) Inactive
Brake Switch 1 Inactive
Brake Switch 2 Inactive
Clutch Switch Inactive
Vehicle Speed 0 km/h
Cruise Control Tip Switch Not Programmed
Cruise Control Not Programmed
Vehicle Speed in Cruise Control Range Inactive
EGR Valve (Exhaust-Gas Recirculation) Inactive
EGR Position Command (Exhaust- Gas Recirculation) 0 %
EGR Position Feedback (Exhaust Gas Recirculation) 0.00 V
Fuel Tank Ventilation Valve 0 %
Knock Control Inactive
B1S1 O2 Sensor Heater (Bank 1 Sensor 1) Active
B1S1 O2 Sensor (Bank 1 Sensor 1) 104 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1) Lean
B1S2 O2 Sensor Heater (Bank 1 Sensor 2) Active
B1S2 O2 Sensor (Bank 1 Sensor 2) 403 mV
B1S2 Air/Fuel Ratio (Bank 1 Sensor 2) Rich
B1 Long Term Fuel Trim (Bank 1) 6 %
B1 Short Term Fuel Trim (Bank 1) 5 %
Requested Torque (Traction Control) 400 Nm
A/C Relay (Air Conditioning) Inactive
A/C Cutoff Mode (Air Conditioning) System OK
Malfunction Indicator (MI) Off
Service Vehicle Soon (SVS) Indicator Off
Fan Relay 1 Inactive
Fan Relay 2 Inactive
Idle Speed Offset Inactive
Ignition Dwell Angle 0.2 ms
Ignition Spark Angle 11.7 °CA
B1 Knock Sensor Signal (Bank 1) 0.63 V
Knock Retard Cylinder 1 0 °CA
Knock Retard Cylinder 2 0 °CA
Knock Retard Cylinder 3 0 °CA
Knock Retard Cylinder 4 0 °CA
Ignition Status On 12V
ETC Limp Home Mode (Electronic Throttle Control) Inactive
Total Misfire 0
Crank Angle Sensing Error Learn Attempts 0
Fuel Tank Ventilation Valve Inactive
Tank Sensor 0.00 V
Tank Sensor 5 L
So heres my thinking correct me if im wrong, If it was burning oil wouldnt a sensor somewhere detect this and throw up some codes especially if the dipstick was clean in 10 days?
This their is oil at the back of the engine could it be possible its only burning a little oil and possibly leaking the rest (only when the engine is running) as i cant find any puddles of oil anywhere. I have looked around the cam gasket and one of the bolts 2nd from the left on the top is broken. The oil at the back of the engine is actually clean(ish) oil (yellowish), so it must be from when i just put it in, what other gaskets could i check
MATT
The egr valve code above is after i cleared the code and after a run of 30 miles. it still shows the egr but the EML light is off
