shiny new stuff of courseWhat for now?
the vx220 has a huge coolant system with the rad at the very front and the engine at the back, so I used the 115 litre craigdavies pump, the astra coolant system would probably only need the 85Litre versionhow about the 80l pump any need for the 115l ?
whats the water content in a vx ? i know the astra is about 7-8lthe vx220 has a huge coolant system with the rad at the very front and the engine at the back, so I used the 115 litre craigdavies pump, the astra coolant system would probably only need the 85Litre version
yes off with the chain!
maybe not quite yet, a slight change of plans means the milestone will have to wait a little longerwell this winters project is going to be quite a milestone in my vx220's life, some major work is planned and it will be happening shortly
A year later and I have finally got around to fitting the new shims (with Duralac anti-corrosion paste) - the red arrow points to their locationsome nice Lotus Europa subframe shims and bolts arrived today
These are a notorious vx220 corrosion point, so even though I have cleaned mine when it was rebuilt in 2006/7 I will be replacing them and adding some anti-corrosion protection.
the Lotus parts are usually half the price of vauxhall, even though vauxhall supply Lotus with themMakes you wonder sometimes who actually looked at those parts and said "Ooooh I wonder if they'll fit my xyz". I find it fascinating how people find these things out without a lot of trial and error.
