Ecu landed at regal yesterday. got the call to say it was ready today.... apprently it was brain dead, and needed reviving with tech 2, so its on route back to me....
i wonder if the tech2 remotely loads up the ecu using a generic boot loader via the rs232 port on the tech2 to a computer / pc then flashes it [reprogrammes it]
Back up and running thanks to chris at regal... also fitted a new starter motor to see if thats my charging/starting issue....and it only cured it,, charging at a healthy 14.4 volts now....
