Tried to remap the thing today, so as a precaution put the charger on the batt,(always do just incase). Downloaded map to ipf, connected ipf to car and way to go.
Mid map battery died... red light on ipf,
So plugged into laptop. which said ipf in recovery mode, please reconnect to car, so did this, and another red light... plugged ipf back into lappy,
So tried to get ecu codes, which are all f**ked up by the seems, so ipf wont talk to ecu and the ecu wont talk to the ipf
And to top it all , the fans and P/s pump are flat out at all times, even with the ignition off....
Reading up on aoc , it seems the batt goin flat puts the ecu into sleep mode... so both the ecu and my ipf may need to goto regal so they can get the rescue files from eds in germany to wake the blighter up again...
So phone call to regal 1st thing monday is in order.... IF that fails.... the coupe is goin to end up the same way as my Vec did....
