Sony RM-X4S Remote for Car PC
Let the hacking continue... This time I've hacked a Sony RM-X4S Remote to Control my Car PC.
I already have the steering wheel controls for general control and heated seat switches converted for menu selection but the Sony RM-X4S Remote is a combination of the two. My steering wheel controls require investigation as the Mk6 conversion has not worked properly since installation - I just need to remove the steering wheel controls and check the wiring.
The Sony RM-X4S Remote has what's known as a resistive ladder internally. General resistive ladders are open circuit or very high resistance until a button is pressed. The button press allows the circuit to complete at a lower resistance to which the detection device reacts.
Here's my calculations for the Arduino sketch (program) - For anyone interested in more details drop me a PM...
Here's the Sony RM-X4S Remote (I have a new one for fitment to the car thanks to @autosparks)...
Next job is to create a loom to supply 5v (taken from the USB hub
), a load resistor (in this case 4.7k), the Arduino Uno voltage monitoring lead and a 3.5mm female jack for the Sony RM-X4S Remote to plug into.
The lead completed - not bad for the prototype test lead
And fitted in the car for testing...
When fitted properly I'll post a pick of the actual location, likely to be on the steering column.
